Witam
Mam podobny problem co założyciel wątku. TO znaczy podczas normalnej pracy na komputerze (normalnej czyli przeglądanie internetu, korzystanie z worda, ewentualenia power pointa) w ciągu miesiące jakieś 3 czy 4 razy wyskoczył mi blue screen
dzieje się to w najmniej oczekiwanych momentach.
Pobrałem program debugging tools for windows. Poniżej informacje które podał program. Niestety kompletnie nic z nich nie rozumiem
Proszę o pomoc.
Microsoft ® Windows Debugger Version 6.6.0007.5
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y argument when starting the debugger. *
* using .sympath and .sympath+ *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrnlmp.exe -
Windows Vista Kernel Version 7600 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7600.16385.amd64fre.win7_rtm.090713-1255
Kernel base = 0xfffff80002053000 PsLoadedModuleList = 0xfffff800
02290e50
Debug session time: Thu Dec 30 18:10:25.802 2010 (GMT+1)
System Uptime: 0 days 6:44:35.443
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*** ERROR: Symbol file could not be found. Defaulted to export symbols for dxgkrnl.sys -
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 116, {fffffa800a554390, fffff88000dd3c98, 0, 2}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: dxgkrnl!_TDR_RECOVERY_CONTEXT ***
*** work. ***
*** work. ***
*** work. ***
*** Type referenced: dxgkrnl!DXGADAPTER ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** Type referenced: nt!KPRCB ***
*** work. ***
*** work. ***
*** work. ***
*** work. ***
*** ERROR: Symbol file could not be found. Defaulted to export symbols for dxgmms1.sys -
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by : atikmpag.sys ( atikmpag+5c98 )
Followup: MachineOwner
