Ubuntu 18.10 - problem z uruchomieniem po aktualizacji z wersji 18.04 LTS
@anon41799040 Po wpisaniu pierwszego polecenia:
sudo dpkg --force depends -P libnvidia-gl-390
Konsola zwróciła:
dpkg: ostrzeżenie: ignorowanie żądania usunięcia pakietu libnvidia-gl-390:i386, który nie jest zainstalowany
Po wprowadzeniu drugiego polecenia:
sudo dpkg --force depends -P libnvidia-gl-390:i386
Konsola zwraca:
Czyli wychodzi ma to, że te pakiety nie są zainstalowane.
Pokaż wynik:
dpkg -l | grep nvidia
@marcin82 Po wprowadzeniu polecenia:
konsola zwraca:
ii libnvidia-cfg1-390:amd64 390.87-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ri libnvidia-common-390 390.87-0ubuntu1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-390:amd64 390.87-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-compute-390:i386 390.87-0ubuntu1 i386 NVIDIA libcompute package
ii libnvidia-decode-390:amd64 390.87-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-390:i386 390.87-0ubuntu1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-390:amd64 390.87-0ubuntu1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-390:i386 390.87-0ubuntu1 i386 NVENC Video Encoding runtime library
ii libnvidia-fbc1-390:amd64 390.87-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-390:i386 390.87-0ubuntu1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
iU libnvidia-ifr1-390:amd64 390.87-0ubuntu1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
iU libnvidia-ifr1-390:i386 390.87-0ubuntu1 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
rc nvidia-384 390.87-0ubuntu1 amd64 Transitional package for nvidia-driver-390
ii nvidia-compute-utils-390 390.87-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-dkms-390 390.87-0ubuntu1 amd64 NVIDIA DKMS package
iU nvidia-driver-390 390.87-0ubuntu1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-390 390.87-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-390 390.87-0ubuntu1 amd64 NVIDIA kernel source package
rc nvidia-opencl-icd-340 340.107-0ubuntu2 amd64 NVIDIA OpenCL ICD
rc nvidia-opencl-icd-384 390.48-0ubuntu3 amd64 Transitional package for nvidia-headless-390
ii nvidia-prime 0.8.10 all Tools to enable NVIDIA’s Prime
ii nvidia-settings 390.77-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-390 390.87-0ubuntu1 amd64 NVIDIA driver support binaries
ii xserver-xorg-video-nvidia-390 390.87-0ubuntu1 amd64 NVIDIA binary Xorg driver
Co to za komputer, czyżby laptop z podwójną kartą GPU.
Może inaczej, bo nie wszystko idzie tak jak powinno. Zróbmy tak byś mógł korzystać z komputera bez "recovery mode”. Zaloguj się jeszcze raz w "recovery mode” z prawem do zapisu. I sprawdź jaki masz domyślny menadżer logowania.
cat /etc/X11/default-display-manager
Jeżeli jest to domyślny dla Ubuntu gdm3 to go wyłącz.
systemctl disable --now gdm
lub tak
systemctl disable gdm
I uruchom komputer ponownie “normalnie”, teraz nie uruchomi się sesja graficzna logowania (nie zablokuje się) i będziesz mógł przejść na terminal może być drugi, skrótem Ctrl-Alt-f2. Zaloguj się i spróbuj, jeszcze raz to co pisałem wcześniej, ale też musisz mieć internet działający.
Czy ty miałeś internet działający w trybie "recovery mode”, bo pytam już enty raz, a ty ani razu mi nie odpowiedziałeś.
Tak, miałem i mam nadal! Co do tego logowania, to spróbuję jutro. Napisz mi tylko jak potem ten menedżer włączyć.
Korzystać z kompa mogę, bo Ubuntu to mój drugi OS obok Windowsa 10 postawiony.
systemctl enable gdm
lub
systemctl enable --now gdm
Wiadomo na czym polega różnica, łatwo się domyśleć po co jest now. Tylko tego na razie nie włączaj, nie jest potrzebny do uruchomienia sesji graficznej, a przy źle działających sterownikach taka automatyka tylko przeszkadza.
Jeszcze jedno, napisałem.
Hej!
To wyłączenie GDM3 poprzez polecenie:
Nic nie dało. Uruchamianie systemu w normalnym trybie zatrzymuje się na:
Started bpfilter
Postanowiłem jeszcze zapodać Wam zawartość pliku sources.list przy użyciu polecenia:
cat /etc/apt/sources.list
Oto, co zwróciła konsola:
Ubuntu - podstawowe repozytoria
deb http://pl.archive.ubuntu.com/ubuntu/ cosmic main restricted universe multiverse
deb-src http://pl.archive.ubuntu.com/ubuntu/ cosmic main restricted universe multiverse
deb http://pl.archive.ubuntu.com/ubuntu/ cosmic-updates main restricted universe multiverse
deb-src http://pl.archive.ubuntu.com/ubuntu/ cosmic-updates main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu cosmic-security main restricted universe multiverse
deb-src http://security.ubuntu.com/ubuntu cosmic-security main restricted universe multiverse
deb https://dl.winehq.org/wine-builds/ubuntu/ bionic main # wyłączony podczas aktualizacji do bionic
deb-src https://dl.winehq.org/wine-builds/ubuntu/ xenial main
deb https://dl.winehq.org/wine-builds/ubuntu bionic main # wyłączony podczas aktualizacji do bionic
deb-src https://dl.winehq.org/wine-builds/ubuntu xenial main
Mały problem jest z tym że ja nie używam Ubuntu, ale niech nie myśli twój system że to mu pomoże. :slight_smile:
Można mu “zabrać” jeszcze plik konfiguracyjny nvidii, ale to może problem nie tylko ze sterownikami nvidii.
Masz pomieszane repozytoria różnych wersji Ubuntu, czy robisz to świadomie. I to nie są wszystkie twojej repozytoria (resztę masz w /etc/apt/sources.list.d/), masz na przykład repozytoria ze sterownikami nvidii.
http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu cosmic/main
Zawsze lepiej jest używać tylko oficjalnych, zwłaszcza przy aktualizacji. Sprawdzałem to repozytorium, oferują sterowniki nowsze i też w wersji beta, niby działają, ale nie wiem czy były ci do czegoś potrzebne. Oficjalne dla Ubuntu 18.10, bez źródeł to.
deb http://archive.ubuntu.com/ubuntu/ cosmic main restricted
deb http://security.ubuntu.com/ubuntu/ cosmic-security main restricted
deb http://archive.ubuntu.com/ubuntu/ cosmic-updates main restricted
I zawierają sterowniki własnościowe Nvidia 390, które wystarczą dla twojej karty.
Bardzo długo “odpowiadasz”, dlatego by nie robić tego miesiącami napiszę więcej, tylko sam musisz uważać by nie uszkodzić sobie systemu bardziej. W Debianie czasami jest inaczej musiałem sprawdzić “ścieżki” na livecd Ubuntu.
No to znowu na "recovery mode” w trybie zapisu, i tak sprawdź w
nano /etc/gdm3/custom.conf
Czy wpis blokujący ładowanie Wayland-a jest w takiej postaci.
WaylandEnable=false
Bez hash-a, ma być tak jak widać. Bo może być i z tym problem że gdm za Xorg-a próbuje uruchomić Wayland-a, a o ile mi wiadomo, to on dalej nie działa na sterownikach nvidii prawidłowo. Dawno nie sprawdzałem.
Wolałem odinstalować z tobą sterowniki przy normalnym trybie logowania w terminalu i mieć większą kontrole na tym, ale możesz tego spróbować na recovery też. Między cudzysłowami ma być tylko jedna spacja, sprawdź wcześniej tak bez odinstalowywania, czy się nie pomyliłeś (jak lista się nie mieści, a chcesz zobaczyć całość, możesz użyć na końcu “| more”).
dpkg -l | grep nvidia | cut -d " " -f 3
To pokaże zainstalowane pakiety związane z nvidią, teraz jak lista jest prawidłowa to spróbuj odinstalować je, z root-a będzie wyglądać to tak.
dpkg -l | grep nvidia | cut -d " " -f 3 | xargs dpkg --purge
Jak dalej się nie uda, to możesz przy szczególnej uwadze dodać na końcu --force-all.
dpkg -l | grep nvidia | cut -d " " -f 3 | xargs dpkg --purge --force-all
Powinno się to sprawdzić przy mniej restrykcyjnych opcjach, ale w tym trybie pomocy nie jest to wygodne, a czasochłonne.
Jak odinstalujesz, a z przełącznikiem --force-all polecą na pewno (chyba że nie masz uprawnień do zapisu), to trzeba zrobić to o czym pisałem wcześniej. Wyczyścić repozytoria tylko do oficjalnej wersji, i wydać polecenia.
apt-get clean ;  apt-get update ; apt-get upgrade ; apt-get dist-upgrade
I ewentualnie zainstalować sterowniki, lub już w “normalnym” trybie logowania.
apt-get install nvidia-driver-390
Uwaga dopisane: Przypomniało mi się że miałem zapytać, czy ty masz/miałeś dostatecznie dużo wolnego miejsca dla tej aktualizacji co robiłeś.
du -h
Zapomniałem jeszcze, ale o tym pewnie pamiętasz już, że może pojawić się konieczność uruchomienia polecenia. Tego;
apt-get --fix-broken install
lub tego;
apt-get install -f
@anon1494722
Przeinstalowałem Ubuntu i wszystko chodzi. Zdecydowałem się to zrobić, bo nawet
sudo su
nie działało.
To teraz zerknij na narzędzie o nazwie Timeshift - ustaw sobie tworzenie kopii raz w tygodniu i w razie problemów zamiast reinstalować system, wystarczy że odtworzysz jedną z wcześniejszych migawek.
Tak jak pisałem i tak to wygląda dalej, problem był nie tylko ze sterownikiem nvidii, nie doszliśmy czy pomieszane repozytoria, brak miejsca, czy może coś innego. Szkoda że nie pokazałeś chociaż ile tam miałeś wolnego miejsca na tą aktualizację, tak jak prosiłem.
W “recovery mode” system działa na specjalnie do tego celu zarezerwowanym miejscu na dysku, niedostępnym w normalnym trybie pracy, i będzie działał nawet jak się zapełni całą przestrzeń przyznaną na system.
Zawsze przed dużą aktualizacją trzeba sprawdzić czy mamy wystarczającą ilość miejsca na pobranie i instalacje nowych pakietów. Zwłaszcza że instalator pokazuje ile jest potrzebne, przed zatwierdzeniem zgody na instalacje. Drugą rzeczą jest „wyłączenie” nieoficjalnych repozytoriów i przeprowadzenie aktualizacji do nowej wersji systemu tylko z oficjalnych źródeł.
@anon1494722
Wiesz co? Mam kolejny problem, tym razem z bootowaniem. Po zainstalowaniu Ubuntu i restarcie oraz wyborze Ubuntu w GRUB’ie system pięknie wstaje. Jednak po uruchomieniu Windowsa 10, który jest moim głównym OS’em, a potem gdy chciałem wrócić do Uvuntu spotkała mnie niemiła niespodzianka. Mianowicie… system nie wstaje! Bootowanie zatrzymuje się na:
fsck exited with status code 8
czy jakoś tak.
Wywołanie polecenia:
sudo fsck /dev/sda5
pomaga, ale po ponownym skorzystaniu z Windowsa sytuacja się powtarza.
Instalowałem ten system 3 razy z Pendrive’a i zawsze jest to samo.
Czy były naprawione jakieś błędy przy tym. Uruchom komputer z tego pendrive-a, sprawdź czy sda5 to jest ta właściwa partycja dla tego Ubuntu, na wszelki wypadek.
sudo fdisk -l /dev/sda
Jak nie jesteś przekonany to nic nie rób dalej, tylko pokaż wynik.
Jeżeli jednak wiesz że jest to partycja z Ubuntu, to.
Przy niezamontowanej partycji, wymuś sprawdzanie nawet jak nie ma błędów z opcją automatycznego naprawiania gdyby jednak były. Dla sda5.
sudo fsck -f -y /dev/sda5
Pokaż wynik. I sprawdź czy problem dalej występuje. Jak tak to, nie reperuj systemu plików przy uruchamianiu tylko z livecd zrób to samo i też pokaż wynik.
Windows ma włączone fast start, domyślną hibernację - zamrożony system plików. Dlatego linuks wali błędem.
Myślałem o tym nawet teraz jak pisałem tamtego posta, ale używał już takiej konfiguracji dual-booting wcześniej, to chyba o tym wie. No ale zobaczymy.
Ja to fast start wyłączyłem. Co do tego fsck i sprawdzania dysku, to zrobię to jutro, bo za bardzo nie mam czasu teraz.
Po wpisaniu komendy:
z poziomu Live Ubuntu, dostałem coś takiego:
fsck from util-linux 2.32
e2fsck 1.44.4 (18-Aug-2018)
ext2fs_open2: Superblock checksum does not match superblock
fsck.ext4: Superblock invalid, trying backup blocks…
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
Free blocks count wrong for group #0 (23489, counted=20834).
Fix? yes
Free blocks count wrong for group #1 (31735, counted=774).
Fix? yes
Free blocks count wrong for group #2 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #3 (31735, counted=1015).
Fix? yes
Free blocks count wrong for group #4 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #5 (31735, counted=1015).
Fix? yes
Free blocks count wrong for group #6 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #7 (31735, counted=1015).
Fix? yes
Free blocks count wrong for group #8 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #9 (31735, counted=1015).
Fix? yes
Free blocks count wrong for group #10 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #11 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #12 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #13 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #14 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #15 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #16 (24528, counted=15590).
Fix? yes
Free blocks count wrong for group #17 (32768, counted=0).
Fix? yes
Free blocks count wrong for group #18 (32768, counted=15376).
Fix? yes
Free blocks count wrong for group #19 (32768, counted=16797).
Fix? yes
Free blocks count wrong for group #20 (32768, counted=2815).
Fix? yes
Free blocks count wrong for group #21 (32768, counted=9424).
Fix? yes
Free blocks count wrong for group #22 (32768, counted=30567).
Fix? yes
Free blocks count wrong for group #23 (32768, counted=10271).
Fix? yes
Free blocks count wrong for group #24 (32768, counted=17277).
Fix? yes
Free blocks count wrong for group #25 (31735, counted=9237).
Fix? yes
Free blocks count wrong for group #26 (32768, counted=6444).
Fix? yes
Free blocks count wrong for group #27 (31735, counted=21359).
Fix? yes
Free blocks count wrong for group #28 (32768, counted=1534).
Fix? yes
Free blocks count wrong for group #29 (32768, counted=770).
Fix? yes
Free blocks count wrong for group #30 (32768, counted=15564).
Fix? yes
Free blocks count wrong for group #31 (32768, counted=6806).
Fix? yes
Free blocks count wrong for group #32 (24528, counted=22977).
Fix? yes
Free blocks count wrong for group #33 (32768, counted=55).
Fix? yes
Free blocks count wrong for group #34 (32768, counted=1768).
Fix? yes
Free blocks count wrong for group #35 (32768, counted=4186).
Fix? yes
Free blocks count wrong for group #36 (32768, counted=3935).
Fix? yes
Free blocks count wrong for group #37 (32768, counted=13759).
Fix? yes
Free blocks count wrong for group #38 (32768, counted=16550).
Fix? yes
Free blocks count wrong for group #39 (32768, counted=30772).
Fix? yes
Free blocks count wrong for group #41 (32768, counted=32755).
Fix? yes
Free blocks count wrong for group #42 (32768, counted=16931).
Fix? yes
Free blocks count wrong for group #43 (32768, counted=18311).
Fix? yes
Free blocks count wrong for group #44 (32768, counted=32538).
Fix? yes
Free blocks count wrong for group #48 (24528, counted=23132).
Fix? yes
Free blocks count wrong for group #49 (31735, counted=30679).
Fix? yes
Free blocks count wrong for group #64 (24528, counted=23154).
Fix? yes
Free blocks count wrong for group #65 (32768, counted=30995).
Fix? yes
Free blocks count wrong for group #80 (24528, counted=23182).
Fix? yes
Free blocks count wrong for group #81 (31735, counted=27984).
Fix? yes
Free blocks count wrong for group #96 (24528, counted=23181).
Fix? yes
Free blocks count wrong for group #97 (32768, counted=32441).
Fix? yes
Free blocks count wrong for group #112 (24528, counted=23811).
Fix? yes
Free blocks count wrong for group #113 (32768, counted=121).
Fix? yes
Free blocks count wrong for group #114 (32768, counted=7690).
Fix? yes
Free blocks count wrong for group #115 (32768, counted=11194).
Fix? yes
Free blocks count wrong for group #116 (32768, counted=9359).
Fix? yes
Free blocks count wrong for group #117 (32768, counted=8827).
Fix? yes
Free blocks count wrong for group #118 (32768, counted=24970).
Fix? yes
Free blocks count wrong for group #128 (24528, counted=24512).
Fix? yes
Free blocks count wrong for group #144 (24528, counted=24527).
Fix? yes
Free blocks count wrong for group #160 (24528, counted=24527).
Fix? yes
Free blocks count wrong for group #176 (24528, counted=24526).
Fix? yes
Free blocks count wrong for group #192 (24528, counted=24520).
Fix? yes
Free blocks count wrong for group #208 (24528, counted=23409).
Fix? yes
Free blocks count wrong for group #209 (32768, counted=20360).
Fix? yes
Free blocks count wrong for group #240 (24528, counted=22964).
Fix? yes
Free blocks count wrong for group #241 (32768, counted=5980).
Fix? yes
Free blocks count wrong for group #242 (32768, counted=12096).
Fix? yes
Free blocks count wrong for group #243 (31735, counted=28151).
Fix? yes
Free blocks count wrong for group #244 (32768, counted=8847).
Fix? yes
Free blocks count wrong for group #245 (32768, counted=5440).
Fix? yes
Free blocks count wrong for group #246 (32768, counted=4781).
Fix? yes
Free blocks count wrong for group #256 (24528, counted=23156).
Fix? yes
Free blocks count wrong for group #257 (32768, counted=5835).
Fix? yes
Free blocks count wrong for group #272 (24528, counted=23112).
Fix? yes
Free blocks count wrong for group #273 (32768, counted=2568).
Fix? yes
Free blocks count wrong for group #274 (32768, counted=15632).
Fix? yes
Free blocks count wrong for group #288 (24528, counted=23113).
Fix? yes
Free blocks count wrong for group #289 (32768, counted=11820).
Fix? yes
Free blocks count wrong for group #290 (32768, counted=32670).
Fix? yes
Free blocks count wrong for group #304 (24528, counted=23151).
Fix? yes
Free blocks count wrong for group #305 (32768, counted=5597).
Fix? yes
Free blocks count wrong for group #320 (24528, counted=23122).
Fix? yes
Free blocks count wrong for group #321 (32768, counted=18852).
Fix? yes
Free blocks count wrong for group #323 (32768, counted=23987).
Fix? yes
Free blocks count wrong for group #324 (32768, counted=111).
Fix? yes
Free blocks count wrong for group #325 (32768, counted=11449).
Fix? yes
Free blocks count wrong for group #326 (32768, counted=29150).
Fix? yes
Free blocks count wrong for group #327 (32768, counted=32748).
Fix? yes
Free blocks count wrong for group #336 (24528, counted=22729).
Fix? yes
Free blocks count wrong for group #337 (32768, counted=1470).
Fix? yes
Free blocks count wrong for group #338 (32768, counted=15313).
Fix? yes
Free blocks count wrong for group #339 (32768, counted=30288).
Fix? yes
Free blocks count wrong for group #352 (24528, counted=22702).
Fix? yes
Free blocks count wrong for group #353 (32768, counted=26017).
Fix? yes
Free blocks count wrong for group #354 (32768, counted=32363).
Fix? yes
Free blocks count wrong for group #355 (32768, counted=8077).
Fix? yes
Free blocks count wrong for group #356 (32768, counted=19340).
Fix? yes
Free blocks count wrong for group #368 (24528, counted=22729).
Fix? yes
Free blocks count wrong for group #369 (32768, counted=2460).
Fix? yes
Free blocks count wrong for group #370 (32768, counted=24472).
Fix? yes
Free blocks count wrong for group #384 (24528, counted=22185).
Fix? yes
Free blocks count wrong for group #385 (32768, counted=12530).
Fix? yes
Free blocks count wrong for group #386 (32768, counted=32019).
Fix? yes
Free blocks count wrong for group #400 (24528, counted=22755).
Fix? yes
Free blocks count wrong for group #401 (32768, counted=1138).
Fix? yes
Free blocks count wrong for group #402 (32768, counted=28556).
Fix? yes
Free blocks count wrong for group #416 (24528, counted=23403).
Fix? yes
Free blocks count wrong for group #417 (32768, counted=7182).
Fix? yes
Free blocks count wrong for group #418 (32768, counted=17149).
Fix? yes
Free blocks count wrong for group #419 (32768, counted=8781).
Fix? yes
Free blocks count wrong for group #420 (32768, counted=7580).
Fix? yes
Free blocks count wrong for group #422 (32768, counted=32092).
Fix? yes
Free blocks count wrong for group #423 (32768, counted=24279).
Fix? yes
Free blocks count wrong for group #424 (32768, counted=20258).
Fix? yes
Free blocks count wrong for group #425 (32768, counted=20418).
Fix? yes
Free blocks count wrong for group #426 (32768, counted=1090).
Fix? yes
Free blocks count wrong for group #427 (32768, counted=25650).
Fix? yes
Free blocks count wrong for group #428 (32768, counted=24784).
Fix? yes
Free blocks count wrong for group #429 (32768, counted=7029).
Fix? yes
Free blocks count wrong for group #430 (32768, counted=16674).
Fix? yes
Free blocks count wrong for group #431 (32768, counted=30029).
Fix? yes
Free blocks count wrong for group #432 (24528, counted=23335).
Fix? yes
Free blocks count wrong for group #433 (32768, counted=9844).
Fix? yes
Free blocks count wrong for group #434 (32768, counted=7273).
Fix? yes
Free blocks count wrong for group #435 (32768, counted=4169).
Fix? yes
Free blocks count wrong for group #436 (32768, counted=3526).
Fix? yes
Free blocks count wrong for group #437 (32768, counted=8110).
Fix? yes
Free blocks count wrong for group #438 (32768, counted=5339).
Fix? yes
Free blocks count wrong for group #439 (32768, counted=4442).
Fix? yes
Free blocks count wrong for group #440 (32768, counted=6827).
Fix? yes
Free blocks count wrong for group #441 (32768, counted=23643).
Fix? yes
Free blocks count wrong for group #442 (32768, counted=21437).
Fix? yes
Free blocks count wrong for group #443 (32768, counted=14037).
Fix? yes
Free blocks count wrong for group #444 (32768, counted=31279).
Fix? yes
Free blocks count wrong (14692903, counted=12508575).
Fix? yes
Free inodes count wrong for group #0 (8197, counted=8192).
Fix? yes
Free inodes count wrong for group #32 (8208, counted=5).
Fix? yes
Directories count wrong for group #32 (0, counted=1380).
Fix? yes
Free inodes count wrong for group #33 (8208, counted=7187).
Fix? yes
Directories count wrong for group #33 (0, counted=12).
Fix? yes
Free inodes count wrong for group #48 (8208, counted=2795).
Fix? yes
Directories count wrong for group #48 (0, counted=1388).
Fix? yes
Free inodes count wrong for group #64 (8208, counted=4468).
Fix? yes
Directories count wrong for group #64 (0, counted=1373).
Fix? yes
Free inodes count wrong for group #80 (8208, counted=4288).
Fix? yes
Directories count wrong for group #80 (0, counted=1343).
Fix? yes
Free inodes count wrong for group #96 (8208, counted=4472).
Fix? yes
Directories count wrong for group #96 (0, counted=1342).
Fix? yes
Free inodes count wrong for group #112 (8208, counted=2824).
Fix? yes
Directories count wrong for group #112 (0, counted=684).
Fix? yes
Free inodes count wrong for group #128 (8208, counted=8180).
Fix? yes
Directories count wrong for group #128 (0, counted=16).
Fix? yes
Free inodes count wrong for group #144 (8208, counted=8207).
Fix? yes
Directories count wrong for group #144 (0, counted=1).
Fix? yes
Free inodes count wrong for group #160 (8208, counted=8207).
Fix? yes
Directories count wrong for group #160 (0, counted=1).
Fix? yes
Free inodes count wrong for group #176 (8208, counted=8206).
Fix? yes
Directories count wrong for group #176 (0, counted=2).
Fix? yes
Free inodes count wrong for group #192 (8208, counted=8112).
Fix? yes
Directories count wrong for group #192 (0, counted=8).
Fix? yes
Free inodes count wrong for group #208 (8208, counted=4784).
Fix? yes
Directories count wrong for group #208 (0, counted=1119).
Fix? yes
Free inodes count wrong for group #240 (8208, counted=89).
Fix? yes
Directories count wrong for group #240 (0, counted=877).
Fix? yes
Free inodes count wrong for group #241 (8208, counted=153).
Fix? yes
Directories count wrong for group #241 (0, counted=523).
Fix? yes
Free inodes count wrong for group #242 (8208, counted=6164).
Fix? yes
Free inodes count wrong for group #256 (8208, counted=43).
Fix? yes
Directories count wrong for group #256 (0, counted=971).
Fix? yes
Free inodes count wrong for group #257 (8208, counted=5692).
Fix? yes
Directories count wrong for group #257 (0, counted=355).
Fix? yes
Free inodes count wrong for group #272 (8208, counted=0).
Fix? yes
Directories count wrong for group #272 (0, counted=1073).
Fix? yes
Free inodes count wrong for group #273 (8208, counted=4674).
Fix? yes
Directories count wrong for group #273 (0, counted=281).
Fix? yes
Free inodes count wrong for group #288 (8208, counted=2).
Fix? yes
Directories count wrong for group #288 (0, counted=955).
Fix? yes
Free inodes count wrong for group #289 (8208, counted=5197).
Fix? yes
Directories count wrong for group #289 (0, counted=421).
Fix? yes
Free inodes count wrong for group #304 (8208, counted=0).
Fix? yes
Directories count wrong for group #304 (0, counted=1076).
Fix? yes
Free inodes count wrong for group #305 (8208, counted=6429).
Fix? yes
Directories count wrong for group #305 (0, counted=267).
Fix? yes
Free inodes count wrong for group #320 (8208, counted=15).
Fix? yes
Directories count wrong for group #320 (0, counted=1340).
Fix? yes
Free inodes count wrong for group #321 (8208, counted=8055).
Fix? yes
Directories count wrong for group #321 (0, counted=34).
Fix? yes
Free inodes count wrong for group #336 (8208, counted=55).
Fix? yes
Directories count wrong for group #336 (0, counted=880).
Fix? yes
Free inodes count wrong for group #337 (8208, counted=162).
Fix? yes
Directories count wrong for group #337 (0, counted=464).
Fix? yes
Free inodes count wrong for group #338 (8208, counted=8090).
Fix? yes
Directories count wrong for group #338 (0, counted=13).
Fix? yes
Free inodes count wrong for group #352 (8208, counted=125).
Fix? yes
Directories count wrong for group #352 (0, counted=1096).
Fix? yes
Free inodes count wrong for group #353 (8208, counted=3609).
Fix? yes
Directories count wrong for group #353 (0, counted=248).
Fix? yes
Free inodes count wrong for group #368 (8208, counted=45).
Fix? yes
Directories count wrong for group #368 (0, counted=1120).
Fix? yes
Free inodes count wrong for group #369 (8208, counted=7400).
Fix? yes
Directories count wrong for group #369 (0, counted=224).
Fix? yes
Free inodes count wrong for group #384 (8208, counted=98).
Fix? yes
Directories count wrong for group #384 (0, counted=884).
Fix? yes
Free inodes count wrong for group #385 (8208, counted=4832).
Fix? yes
Directories count wrong for group #385 (0, counted=464).
Fix? yes
Free inodes count wrong for group #400 (8208, counted=0).
Fix? yes
Directories count wrong for group #400 (0, counted=230).
Fix? yes
Free inodes count wrong for group #401 (8208, counted=0).
Fix? yes
Directories count wrong for group #401 (0, counted=143).
Fix? yes
Free inodes count wrong for group #402 (8208, counted=1823).
Fix? yes
Directories count wrong for group #402 (0, counted=971).
Fix? yes
Free inodes count wrong for group #416 (8208, counted=819).
Fix? yes
Directories count wrong for group #416 (0, counted=764).
Fix? yes
Free inodes count wrong for group #417 (8208, counted=5512).
Fix? yes
Directories count wrong for group #417 (0, counted=308).
Fix? yes
Free inodes count wrong for group #432 (8208, counted=712).
Fix? yes
Directories count wrong for group #432 (0, counted=1050).
Fix? yes
Free inodes count wrong for group #433 (8208, counted=3938).
Fix? yes
Directories count wrong for group #433 (0, counted=19).
Fix? yes
Free inodes count wrong for group #434 (8208, counted=8053).
Fix? yes
Free inodes count wrong (3759253, counted=3559825).
Fix? yes
Inode bitmap differences: Group 0 inode bitmap does not match checksum.
FIXED.
Block bitmap differences: Group 0 block bitmap does not match checksum.
FIXED.
Jak widać, są błędy, które niby naprawił (fixed). /dev/sda5 to partycja z moim Ubuntu. Jest on zainstalowany cały na jednej partycji (zawsze tak miałem). System plików to EXT4 z księgowaniem.
Jak będą jaja, to napiszę.
[EDIT]
TGego posta pisałem na Windowsie. Kiedy go napisałem postanowiłem odpalić Ubuntu i… d*** system nie wstaje. Czyżby dysk (SSD) padał?
Czy po naprawieniu, sprawdziłeś od razu jeszcze raz, powinien wyjść na czysto bez błędów. Zapomniałem o tym napisać od razu, po reperacji robi się sprawdzanie jeszcze raz by upewnić się że wszystko zostało naprawione.
Jak będziesz na livecd to zrób to dwa razy. Oczywiście wszystko na odmontowanej partycji.
Jak wyjdzie drugi raz z błędami to, pokaż jeszcze to.
sudo fsck -v /dev/sda5
Na tym laivcd, bo może nie chcesz sobie śmiecić w systemie zainstaluj smartmontools.
sudo apt-get update ; sudo apt-get install smartmontools
I pokaż informacje o tym dysku sda smart i info, można całość -a, ale to wystarczy.
sudo smartctl -i /dev/sda ; sudo smartctl --attributes /dev/sda
Później spróbujemy naprawić te superbloki jak się nic nie zmieni i będzie to miało sens, ale wole mieć przedtem te informacje o dysku.
Edycja: A zresztą nie jest to żadna magia, możesz sam ocenić czy sobie poradzisz z naprawą, ja to robię trochę inaczej niż w opisie dla twojego systemu, ale to bez znaczenia.
Ocień swój dysk (ze smart info wszystko będziesz miał, lub pytaj tu), wyciągnij wnioski z informacji uzyskanych z tych poleceń co pisałem wyżej i ostrożnie sprawdź/zrób to, jeżeli będzie taka potrzeba. Lub podawaj wyniki i będziemy to próbować naprawiać razem.
Po drugim wywolaniu polecenia:
nie ma bledow. Jednak pokaze wynik:
sudo fsck -v /dev/sda5`
Oto on:
/dev/sda5: clean, 199439/3759264 files, 2499169/15007744 blocks
Sory za brak polskich znakow, ale pisze ten post z poziomu Live CD, gdzie jest inny uklad klawiatury.
SMART mojego dysku SSD:
Po wpisaniu:
Otrzymuję coś takiego na końcu:
