Mam problem, nie potrafię zainstalować Vbulletina.
Dokładnie chodzi o wypełnienie tego pliku.
Dam w tym poście jego zawartość
<?php
|| # vBulletin 3.6.8
|| # All PHP code in this file is ©2000-2007 Jelsoft Enterprises Ltd. # ||
|| # This file may not be redistributed in whole or significant part. # ||
|| # ---------------- VBULLETIN IS NOT FREE SOFTWARE ---------------- # ||
|| # http://www.vbulletin.com | http://www.vbulletin.com/license.html # ||
| ******NOTE REGARDING THE VARIABLES IN THIS FILE****** |
| If you get any errors while attempting to connect to |
| MySQL, you will need to email your webhost because we |
| cannot tell you the correct values for the variables |
| in this file. |
// ******DATABASE TYPE******
// This is the type of the database server on which your vBulletin database will be located.
// Valid options are mysql and mysqli, for slave support add _slave. Try to use mysqli if you are using PHP 5 and MySQL 4.1+
// for slave options just append _slave to your preferred database type.
$config['Database']['dbtype'] = 'mysql';
// ******DATABASE NAME******
// This is the name of the database where your vBulletin will be located.
// This must be created by your webhost.
$config['Database']['dbname'] = 'forum';
// ******TABLE PREFIX******
// Prefix that your vBulletin tables have in the database.
$config['Database']['tableprefix'] = '';
// ******TECHNICAL EMAIL ADDRESS******
// If any database errors occur, they will be emailed to the address specified here.
// Leave this blank to not send any emails when there is a database error.
$config['Database']['technicalemail'] = 'dbmaster@example.com';
// ******FORCE EMPTY SQL MODE******
// New versions of MySQL (4.1+) have introduced some behaviors that are
// incompatible with vBulletin. Setting this value to "true" disables those
// behaviors. You only need to modify this value if vBulletin recommends it.
$config['Database']['force_sql_mode'] = false;
// ******MASTER DATABASE SERVER NAME AND PORT******
// This is the hostname or IP address and port of the database server.
// If you are unsure of what to put here, leave the default values.
$config['MasterServer']['servername'] = 'localhost';
$config['MasterServer']['port'] = 3306;
// ******MASTER DATABASE USERNAME & PASSWORD******
// This is the username and password you use to access MySQL.
// These must be obtained through your webhost.
$config['MasterServer']['username'] = 'root';
$config['MasterServer']['password'] = '';
// ******MASTER DATABASE PERSISTENT CONNECTIONS******
// This option allows you to turn persistent connections to MySQL on or off.
// The difference in performance is negligible for all but the largest boards.
// If you are unsure what this should be, leave it off. (0 = off; 1 = on)
$config['MasterServer']['usepconnect'] = 0;
// ******SLAVE DATABASE CONFIGURATION******
// If you have multiple database backends, this is the information for your slave
// server. If you are not 100% sure you need to fill in this information,
// do not change any of the values here.
$config['SlaveServer']['servername'] = '';
$config['SlaveServer']['port'] = 3306;
$config['SlaveServer']['username'] = '';
$config['SlaveServer']['password'] = '';
$config['SlaveServer']['usepconnect'] = 0;
// ******PATH TO ADMIN & MODERATOR CONTROL PANELS******
// This setting allows you to change the name of the folders that the admin and
// moderator control panels reside in. You may wish to do this for security purposes.
// Please note that if you change the name of the directory here, you will still need
// to manually change the name of the directory on the server.
$config['Misc']['admincpdir'] = 'admincp';
$config['Misc']['modcpdir'] = 'modcp';
// Prefix that all vBulletin cookies will have
// Keep this short and only use numbers and letters, i.e. 1-9 and a-Z
$config['Misc']['cookieprefix'] = 'bb';
// ********FULL PATH TO FORUMS DIRECTORY******
// On a few systems it may be necessary to input the full path to your forums directory
// for vBulletin to function normally. You can ignore this setting unless vBulletin
// tells you to fill this in. Do not include a trailing slash!
// Example Unix:
// $config['Misc']['forumpath'] = '/home/users/public_html/forums';
// Example Win32:
// $config['Misc']['forumpath'] = 'c:\program files\apache group\apache\htdocs\vb3';
$config['Misc']['forumpath'] = '';
// ******USERS WITH ADMIN LOG VIEWING PERMISSIONS******
// The users specified here will be allowed to view the admin log in the control panel.
// Users must be specified by *ID number* here. To obtain a user's ID number,
// view their profile via the control panel. If this is a new installation, leave
// the first user created will have a user ID of 1. Seperate each userid with a comma.
$config['SpecialUsers']['canviewadminlog'] = '1';
// ******USERS WITH ADMIN LOG PRUNING PERMISSIONS******
// The users specified here will be allowed to remove ("prune") entries from the admin
// log. See the above entry for more information on the format.
$config['SpecialUsers']['canpruneadminlog'] = '1';
// ******USERS WITH QUERY RUNNING PERMISSIONS******
// The users specified here will be allowed to run queries from the control panel.
// See the above entries for more information on the format.
// Please note that the ability to run queries is quite powerful. You may wish
// to remove all user IDs from this list for security reasons.
$config['SpecialUsers']['canrunqueries'] = '';
// ******UNDELETABLE / UNALTERABLE USERS******
// The users specified here will not be deletable or alterable from the control panel by any users.
// To specify more than one user, separate userids with commas.
$config['SpecialUsers']['undeletableusers'] = '';
// ******SUPER ADMINISTRATORS******
// The users specified below will have permission to access the administrator permissions
// page, which controls the permissions of other administrators
$config['SpecialUsers']['superadministrators'] = '1';
// ******DATASTORE CACHE CONFIGURATION*****
// Here you can configure different methods for caching datastore items.
// vB_Datastore_Filecache - for using a cache file
// $config['Datastore']['class'] = 'vB_Datastore_Filecache';
// vB_Datastore_Memcached - for using a Memcache server
// It is also necessary to specify the hostname or IP address and the port the server is listening on
$config['Datastore']['class'] = 'vB_Datastore_Memcached';
$i = 0;
// First Server
$i++;
$config['Misc']['memcacheserver'][$i] = '127.0.0.1';
$config['Misc']['memcacheport'][$i] = 11211;
$config['Misc']['memcachepersistent'][$i] = true;
$config['Misc']['memcacheweight'][$i] = 1;
$config['Misc']['memcachetimeout'][$i] = 1;
$config['Misc']['memcacheretry_interval'][$i] = 15;
// ******The following options are only needed in special cases******
// ******MySQLI OPTIONS*****
// When using MySQL 4.1+, MySQLi should be used to connect to the database.
// If you need to set the default connection charset because your database
// is using a charset other than latin1, you can set the charset here.
// If you don't set the charset to be the same as your database, you
// may receive collation errors. Ignore this setting unless you
// are sure you need to use it.
// $config['Mysqli']['charset'] = 'utf8';
// Optionally, PHP can be instructed to set connection parameters by reading from the
// file named in 'ini_file'. Please use a full path to the file.
// Example:
// $config['Mysqli']['ini_file'] = 'c:\program files\MySQL\MySQL Server 4.1\my.ini';
$config['Mysqli']['ini_file'] = '';
// Image Processing Options
// Images that exceed either dimension below will not be resized by vBulletin. If you need to resize larger images, alter these settings.
$config['Misc']['maxwidth'] = 2592;
$config['Misc']['maxheight'] = 1944;
|| # Downloaded: 15:48, Thu Aug 2nd 2007
|| # CVS: $RCSfile$ - $Revision: 16258 $
Adres bazy danych: mysql.cba.pl
Nazwa bazy danych załóżmy misiek64_pl
Hasło 123456
Proszę o wypełnienie tego tymi danymi. Będę naprawdę bardzo wdzięczny…
Database Error Database error
The database has encountered a problem.
Ja mam niestety taki error
