Ja mam podobny problem. aby oglądać filmy w takiej rozdzielczości. Dźwięk idzie normalnie ale obraz strasznie zwalnia. Mój problem polega na tym, że po jednym formacie i zainstalowaniu wszystkich potrzebnych rzeczy wszystko działało normalnie i sprawnie. Po kolejnym film w ww. rozdzielczości ponownie strasznie zwalnia. Jakaś pomoc?
Parametry komputera:
System Information
Time of this report: 8/4/2008, 09:15:22
Machine name: PRIVAT
Operating System: Windows XP Professional (5.1, Build 2600) Dodatek Service Pack 2 (2600.xpsp_sp2_rtm.040803-2158)
Language: Polish (Regional Setting: Polish)
System Manufacturer: n/a
System Model: n/a
BIOS: Award Medallion BIOS v6.0
Processor: AMD Athlon XP1800+, MMX, 3DNow, ~1.5GHz
Memory: 1024MB RAM
Page File: 464MB used, 1999MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: The registry information for the DirectPlay application ‘Heroes of Might and Magic III’ is missing or damaged. You should reinstall that application. The registry information for the DirectPlay application ‘Heroes of Might and Magic III: Armageddons Blade’ is missing or damaged. You should reinstall that application.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7600 GS
Manufacturer: NVIDIA
Chip type: GeForce 7600 GS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_02E1&SUBSYS_34281458&REV_A2
Display Memory: 256.0 MB
Current Mode: 1152 x 864 (32 bit) (75Hz)
Monitor: Monitor Plug and Play
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6921 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/5/2007 02:41:00, 5773568 bytes
WHQL Logo’d: Yes
WHQL Date Stamp: n/a
VDD: n/d
Mini VDD: nv4_mini.sys
Mini VDD Date: 12/5/2007 02:41:00, 7435392 bytes
Device Identifier: {D7B71E3E-41A1-11CF-E16C-231403C2CB35}
Vendor ID: 0x10DE
Device ID: 0x02E1
SubSys ID: 0x34281458
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B
