Dix
(Dawid Tworzy)
19 Lipiec 2006 21:42
#1
Witam!
Sam chciałem najpierw uzbierać troche informacji o tym błędzie i oto one:
Log z “dumpera”:
Microsoft ® Windows Debugger Version 6.6.0007.5 Copyright © Microsoft Corporation. All rights reserved. Loading Dump File [C] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: *** Invalid *** **************************************************************************** * Symbol loading may be unreliable without a symbol search path. * * Use .symfix to have the debugger choose a symbol path. * * After setting your symbol path, use .reload to refresh symbol locations. * **************************************************************************** Executable search path is: ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image ntoskrnl.exe, Win32 error 2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420 Debug session time: Wed Jul 19 19:36:22.203 2006 (GMT+2) System Uptime: 0 days 0:28:15.827 ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image ntoskrnl.exe, Win32 error 2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Loading Kernel Symbols … Loading User Symbols Loading unloaded module list … Unable to load image nv4_disp.dll, Win32 error 2 *** WARNING: Unable to verify timestamp for nv4_disp.dll *** ERROR: Module load completed but symbols could not be loaded for nv4_disp.dll ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 1000008E, {c0000005, bfad34b6, ba1aca8c, 0} ANALYSIS: Kernel with unknown size. Will force reload symbols with known size. ANALYSIS: Force reload command: .reload /f ntoskrnl.exe=FFFFFFFF804D7000,213F80,42250FF9 ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ***** Kernel symbols are WRONG. Please fix symbols to do analysis. *** WARNING: Unable to verify timestamp for mssmbios.sys *** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys Probably caused by : hardware ( nv4_disp+ff4b6 ) Followup: MachineOwner ---------
Log ze wczoraj ( ten sam błąd ):
Microsoft ® Windows Debugger Version 6.6.0007.5 Copyright © Microsoft Corporation. All rights reserved. Loading Dump File [C] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: *** Invalid *** **************************************************************************** * Symbol loading may be unreliable without a symbol search path. * * Use .symfix to have the debugger choose a symbol path. * * After setting your symbol path, use .reload to refresh symbol locations. * **************************************************************************** Executable search path is: ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image ntoskrnl.exe, Win32 error 2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible Product: WinNt, suite: TerminalServer SingleUserTS Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a420 Debug session time: Tue Jul 18 00:48:34.625 2006 (GMT+2) System Uptime: 0 days 1:34:41.241 ********************************************************************* * Symbols can not be loaded because symbol path is not initialized. * * * * The Symbol Path can be set by: * * using the _NT_SYMBOL_PATH environment variable. * * using the -y argument when starting the debugger. * * using .sympath and .sympath+ * ********************************************************************* Unable to load image ntoskrnl.exe, Win32 error 2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Loading Kernel Symbols … Loading User Symbols Loading unloaded module list … Unable to load image nv4_disp.dll, Win32 error 2 *** WARNING: Unable to verify timestamp for nv4_disp.dll *** ERROR: Module load completed but symbols could not be loaded for nv4_disp.dll ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 10000050, {ba409888, 0, bfac9f33, 0} ANALYSIS: Kernel with unknown size. Will force reload symbols with known size. ANALYSIS: Force reload command: .reload /f ntoskrnl.exe=FFFFFFFF804D7000,213F80,42250FF9 ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ***** Kernel symbols are WRONG. Please fix symbols to do analysis. *** WARNING: Unable to verify timestamp for mssmbios.sys *** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys Probably caused by : nv4_disp.dll ( nv4_disp+f5f33 ) Followup: MachineOwner ---------
Screen błędu ( pojawia się albo “blue screen” albo TEN błąd ):
A teraz sedno sprawy…
Gram sobie w Obliviona i po jakiś 10-13 min. pokazują mi się powyższe błędy. Na 90% chodzi o nv4_disp.dll , ale nie wiem co z tym zrobić…
Dodam jeszcze, że podkręciłem karte graficzną ( narzędziem Nvidi ), ale te błędy i tak pojawiały sie wcześniej… Podczas gry w GTA:SA też sie tak dzieje, tylko, że NIE wyskakuje “blue”, a TYLKO błąd. Temperatury sprawdzałem… są w normie.
Mam takie koncepcje:
Używam teraz takich sterowników do karty graficznej:
Czyli najnowsze stery… odinstaluje je i wgram te z płytki… Czy to coś da?
Musze poszperać w biosie ( czytałem gdzieś, że gdy się podkreca karte trzeba potem coś pozmieniac w WIN ).
Sprawdzałem pamięcia RAM, program szedł ponad 40 min i 0 ERRORÓW ( mam 1024 DDR ). Pozmieniać kości?
Podmienić plik nv4_disp.dll od kogoś, kto ma te same sterowniki?
Błąd ten pojawia się podczas “stresu” na tych “lepszych” grach jeśli chodzi o wymagania… kiedyś F.E.A.R też szwankował, ale tam był “tylko” restart, bez “blue”.
Bardzo Was prosze o pomoc.
Nadal będe szukał przyczyny i podążał Waszymi wskazówkami, tylko pomóżcie.
Dzięki.
squeet
(squeet)
19 Lipiec 2006 22:21
#2
Dix
(Dawid Tworzy)
20 Lipiec 2006 00:02
#3
Wypróbowałem inny sposób… przinstalowałem sterowniki na te z płyty… nic nie pomogło… pojawia sie błąd… ehh…
squeet
(squeet)
20 Lipiec 2006 00:06
#4
Spróbuj w/w sposobów, przede wszystkim naprawy z konsoli.
A później linki.
Napisz jeszcze, czy ten błąd od zawsze występuje czy od pewnego momentu?
P.S. Polecam iść teraz spać, a problemem zająć się rano - umysł lepiej pracuje
JNJN
(JNJN)
20 Lipiec 2006 07:26
#5
Zrób porządek po sterach karty w systemie:
http://forum.dobreprogramy.pl/viewtopic.php?t=9838
i uruchom kompa na sterze systemowym.
Wgraj stery najnowsze do płyty głównej.
I zastosuj ten do XP:
STER
Dodatkowo jak tam napięcia zasilacza i temperatury wszystkiego.
Dix
(Dawid Tworzy)
23 Lipiec 2006 20:04
#6
Przepraszam, że tak późno pisze, ale robiłem “crash” testy wskazane przez Was jak i moje własne.
Wniosek :
Problem był spowodowany PAMIĘCIĄ RAM .
Poprostu przy zmianie karty graficznej dokupiłem drugą koste kamięci RAM, jak się teraz okazało wadliwą.
Grając w Obliviona przez ten czas 10-15 min. komputer musiał korzystać w dużej mierze z mojej starej kostki. A potem korzystał z nowej=wadliwej.
Dzięki za pomoc i okazane zainteresowanie.
